Tcc ?????????????????
Old Mar 25, 2004 | 06:56 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Ok
I understand the lock/unlock tables, thats fairly easy, no big mystery's there.
The mph lockup/unlock is self explanatory as well..
My question is does the mandatory tcc lock(constant) override everything else?
My experience has shown this too be true regardless of what u "think" u have in the unlock tables for low and high gear?
Currently i run with my converter locked at 38 and unlocking at 36mph and have the converter locked using code to make it stay locked unless mph condition or TPS unlocks it...
Great for highway but somewhat less than desirable around town. It no longer unlocks the converter when brakes applied(equally annoying w/out code changes(using stock code) and running a higher stall converter like i am(28-3000range).
Is it possible to turn the mandatory tcc lock into a mandatory tcc unlock below a certain mph? If below 50 mph and brakes applied unlock tcc? Yet retain lockup under normal decel conditions(eng braking)?
Im not yet code enlightened enuff to make this possible by myself (assuming it is possible?) Wondering if anyone else has played around with this same scenario? I'm sure i cant be the only one that finds it annoying
Yes, I do have a switch for unlocking the tcc, but im more of a set it and forget it kind of guy dont like flipping switches and remembering what i have on and off :-)
Thanks and later
Jeremy
Old Mar 25, 2004 | 07:43 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Tcc ?????????????????
The brake switchs supplies power to the TCC. There are two switches in the brake pedal actually 3 including the vac switch.
Anyway, if you push on the brakes the power should be disrupted to the TCC. The ecm grounds the TCC solenoid to apply it.
Old Mar 26, 2004 | 12:39 AM
3.8TransAM's Avatar
you know, i was thinking that...........
brain fried, long week(typed all this 3 times to get it right once)
have to dog back around and see if they came out or are misadjusted or plain junk :-) then go from there
I do this too many hours a week, if is not my own its for the folk who buy Jaguars (ughhhhh)
Later
Jeremy
PS Project total Engine Airfolw begins saturday 89 TTA
UltRoadWarrior9
Apr 28, 2020 10:39 PM
jklein337
Sep 19, 2018 06:23 PM
92camaro350cci
Oct 14, 2015 09:29 AM
ramicio
Sep 28, 2015 01:18 PM
Mark 89Formula
19
Jan 5, 2004 04:14 PM
