blms low so can i
Old Mar 27, 2004 | 09:37 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
blms low so can i
all off my blms are in the 108-123 range dose that mean i can just turn the fuel pressure down a tad
Old Mar 27, 2004 | 10:35 PM
Brent's Avatar
That depends.
There is a minimum amount of FP you need for WOT.
Old Mar 28, 2004 | 01:03 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
If you have an AFPR you can. I wouldn't go below stock.
Old Mar 28, 2004 | 11:40 AM
c4boom's Avatar
Engine: l98 and lo5
i am running a holley unit and it is at 13.5 now
Old Mar 28, 2004 | 06:55 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
13.5? Are you TBI then?
I would try adjusting the VE tables to take out some fuel. Because if you turn the Fuel Pressure down, you are also taking fuel away from your pump shot aswell as wide open which is something you may, or may not want/need.
Old Mar 28, 2004 | 08:19 PM
c4boom's Avatar
Engine: l98 and lo5
i did about an hour of loging today and i need more fuel up top and less down low so a chip change is the only way i can go if i want this thing to run right
Old Mar 29, 2004 | 02:04 PM
Ronny's Avatar
seems like that is what ends up to be THE BOTTOM LINE. MY MODS WERE LEAN ALL OVER DAY ONE.
Old Mar 29, 2004 | 02:13 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
What are your duty cycles like at top end?.
If they're ~70% then I'd add fuel with the chip until into the mid 80s or so. And then raise the F/P, if necessary.
And, worry about the low end as a seperate issue.
Old Mar 29, 2004 | 04:15 PM
c4boom's Avatar
Engine: l98 and lo5
how do i check the duty cycles
it is the stock chip with this setup
its a 88 k2500 with a 350 in it. i have a comp cams extreme energy cam grind # xe249h-12 this cam has 206 212 duration at .05 lift (I/E) and .434 and .444 inches (I/E) of lift. i also have edelbrock TES headers, a holey projection intake, holley tbi unit part# 502-6 with the 65 pph injectors and 3 " exhaust to the muffler (flow master 50 series) and then duel 2 1/2 out the back and last and least the crappy stock swirl port heads. the truck is about 5500-6000 punds with 33" tires and 4.11 gears.
antman89iroc
36
Jan 31, 2016 08:42 AM
BrianI
Oct 3, 2015 12:57 PM
Damon
Sep 26, 2015 04:29 PM
327IROC85
Sep 23, 2015 12:11 AM
ULTM8Z
Sep 16, 2015 09:15 AM
