Swapping intake, getting rid of CSI
Old Apr 7, 2004 | 01:37 PM
just2quickz28's Avatar
Car: 86 IROC
I have a 85 z28 with a 350 TPI under the hood, when i put the motor together i had a machine shop elongate those center holes off my 85 intake to line up wiht my new center bolt style heads. needless to say VAC leak, i was given a 92 TPI setup with everything except the ecm and wiring.
I know i will have to swap my injectors over because the TPI stuff is out of a 305 what am i going to do about that 9th injector, if its not there or plugged in do i have to do anything with it?
Thanks for the help
Matt
Old Apr 8, 2004 | 06:57 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
NM.. completely read over that it was a 85
Kat
Old Apr 8, 2004 | 08:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Swapping intake, getting rid of CSI
Thanks for the help
Matt
Your kinda stuck between a rock and a wall. The '85 ECM requires the CSI for startup and cold running. Best bet is to upgrade the ECM to a '165 and $6E code. Or go to a '730 ECM and $8D (SD).
I don't think that the '165 w/$56E code will support your current MAF (I may be incorrect here), so you may need to change that also (if going with the '165, the '730 uses a MAP sensor, no MAF).
RBob.
Old Apr 8, 2004 | 08:33 AM
SBNova's Avatar
I have an 85 Vette (same 6870 ECM you have) and swapped to the 165 ECM. My 85 MAF works fine.
One other thing- elongating the holes to line up the intake to your heads should not in any way create a vacuum leak. Those bolts are an inch or so away from the ports. As long as theyre tightened within spec, they should create a leak. Now an OIL leak I would believe- as those bolts are known to weep oil if no sealer is applied to them. I would look for another source for that vacuum leak.
Old Apr 8, 2004 | 09:02 AM
11sORbust's Avatar
The 85 maf is exactly the same. I started with the 85 setup then upgraded,also.....
Why did you say it might not work? Someone told me the 85 maf was digital. That's wrong....
Old Apr 8, 2004 | 09:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I had thought that the 85 MAF was a digital MAF. The $32 code has support for it, but the $6E code does not. The $32 code still needs the CSI.
I have also heard that the digital MAFs do work with the analog input to the ECM. What happens is that the low pass filter on that input integrates the duty cycle of the digital MAF, thereby allowing it to work.
Again, this is all stuff I have heard, but not verified personally. Hence the 'I may be incorrect' in my other post.
RBob.
Old Apr 8, 2004 | 12:13 PM
Car: 86 IROC
opps sorry forgot to mention im already running a 165 ECM out of a 87 or 88 car.... im runing that ECM and a brand new MAF wiring harness from painless..... where should i go from here... and i will try to find adifferent source for my Vac leak. thanks
Old Apr 8, 2004 | 12:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Piece of cake, go to the '89 $6E mask. This code handles crank and cold run with the normal 8 injectors. A lot of folks like ARAP, but since it is a Corvette bin will need changes made to it.
Or can throw a stock f-body bin in and go from there.
RBob.
Old Apr 8, 2004 | 01:34 PM
Car: 86 IROC
so it is possible to do what i want, ill start putting together the stuff to burn chips i was asking to make sure i could do it before i started to grab the equipment.... is the prominator worth it?
Old Apr 8, 2004 | 03:25 PM
11sORbust's Avatar
Might check the part numbers, I thought they was the same?? I'm 99% sure it's not a digital maf. My 85 sensor took a dump awhile back. I can open it up and take some pics if you like. We can be 100% sure then one way or the other, yes? Never know it might be digital, I doubt it though...
Orr89RocZ
Apr 25, 2016 08:28 AM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
stalkier
Aug 21, 2015 01:54 AM
355sbcTPI
Aug 19, 2015 04:38 PM
