park/neutral wire into 1227747
I am installing my 700R4 in my car, and want to put the park/neutral switch connection to the computer. Does anyone know the polarity of this wire? I presume that it needs to be grounded when the car is in park or neutral. Is that correct?
I'm assuming this because My wiring diagram shows a switch to ground, and then it says "Park Neutral Switch (A/T) (12V) (except P)" on the diagram.
Also, based on that description and the fact that this signal has a 100K input resistor and a diode to +5V on the schematics, I am assuming that it will tollerate +12V.
I am going to run my park/neutral switch to ground on one side, and to the computer and to a relay on the other side, so it will give my computer what it wants and still disable start when not in park/neutral.
Any help greatly appreciated.
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
The P/N wire goes to one side of the switch and the other side of the switch goes to ground.
Car: check
Engine: check
Transmission: check
Originally posted by yellow73bb
Yes, I understand that. The question is, is it grounded when in park and neutral, or grounded when in gear (1, 2, 3, OD, reverse)?
RBob.
Car: check
Engine: check
Transmission: check
Re: so, what do we do on a manual?
Originally posted by silvernblack
can it just be grounded so it won't matter?
RBob.
Car: 1980 Jeep CJ7
Yep...what Rbob said. That was one of the problems I was having when I first started logging with the Jeep. I hooked the P/N switch up and all was fine...till I found the #$#%@ vacuum leak I had. Now I gotta fix THAT!!!
It never ends...
It never ends...
Car: check
Engine: check
Transmission: check
Originally posted by fire1976
If I have a manual bin, would it still need that input? Just wondering how I could work it out if needed. Maybe a switch on gas pedal, so that when not on gas, ECM would know I'm in neutral or park.
Math
Math
RBob.
Glowsock
Jan 9, 2017 04:06 PM
1227747, 700r4, computer, ecm, gm, installing, neutral, nuetral, parkneutral, parknuetral, switch, tbi, tf727, wire, wiring
