how will the computer react when no injectors are connected?
Old Apr 16, 2004 | 09:57 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
91 TBI car.. stock 746 ECM, ANTT ... (watches as half the people leave becuse its TBI)
if i leave everything, including the stock electronic distrib, and put a carb on top, how will the car react.
the TPS, IAC, and injectors wont be connected.
will it still run spark?
basicly im trying to keep my computer controlled spark, and still run a carb.
Old Apr 16, 2004 | 10:46 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: how will the computer react when no injectors are connected?
BTDT, works like a charm. See paper that describes how it was done on the diy-efi site (w/a '7747).
RBob.
Old Apr 16, 2004 | 11:00 AM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
In a nutshell, yes...I think. There is a writeup somewhere on the DIY EFI board in the GMECM FTP site that describes using a 7747 for spark only control. Here's a link to it.
7747 for spark-only control
Old Apr 16, 2004 | 11:19 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
but does it apply to my 746??
Old Apr 16, 2004 | 11:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Sure thing. The '8746 & '7747 ECMs share the same hardware platform. Only the firmware is different. As that paper also describes all of the spark timing parameters, there will be a difference in the actual bin/PROM addresses.
Check out the writeup, it tells which sensors were used, which DTC's were disabled, and in general how it worked out. It was actually kinda' funny watching the ECM go closed loop and try to adjust the fueling.
RBob.
Old Apr 16, 2004 | 11:44 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
im looking thru that, and all im getting from it is..... confused.
i guess what im asking is, what do i need to do to make it work?
Old Apr 16, 2004 | 01:35 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Most of the paper covers how the SA control operates. The beginning part tells which sensors are used and which DTCs are enabled.
Disable the O2 (13, 44, 45) and the TPS (??) DTC's. Need the MAP, KNOCK, and Coolant (and IAT) sensors. The VSS & O2 was also used but not required.
Are you burning PROMs? If not, then you'll get a constant SES light.
It would work out better if the TPS was hooked up to the carb. So if you can do that. . .
Then bolt up the manifold & carb, regulate the fuel pressure down (w/a bypass regulator), and turn the key.
RBob.
Old Apr 16, 2004 | 02:08 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
RBob.
im not directly burning them.... im sure someone i know online will burn a image for me if i give them the chip and file, but im still a newbie to DIY EFI....
eightsixseven
Dec 16, 2024 01:50 PM
fbirdroller
Sep 2, 2015 10:27 PM
Keith5
Aug 27, 2015 04:37 PM
86IROC112
Aug 21, 2015 07:20 PM
Bryan F
Aug 18, 2015 02:28 PM
