AA mask vs. 8D mask
Old Apr 17, 2004 | 12:10 PM
nhromyak's Avatar
Car: '73 Chevy Blazer
Engine: BBC - 408
Transmission: SM465
AA mask vs. 8D mask
Silly me,
I just foud out my Howell chip is using an AA mask.
Looking at TunerPro using the Super_8Dmv1.ecu,
Constants
Chip Code Mask
AA
Comparing it to the AXCN bin, it's 8D.
What is this? Is it compatible, or is it time to start over with a AA mask?
I looked around for an AA mask to no avail.
It's in a 7730.
Should I simply change the mask on the new chips I burn to 8D?
Thanks.
Old Apr 17, 2004 | 01:53 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: AA mask vs. 8D mask
Originally posted by nhromyak
Silly me,
Interesting. That isn't a mask id at all, it is the value used to bypass the checksum calculation (the $AA). I'd check the Howell bin for table locations and code fragments to see which mask was actually used.
RBob.
Old Apr 17, 2004 | 03:21 PM
nhromyak's Avatar
Engine: BBC - 408
Transmission: SM465
Re: Re: AA mask vs. 8D mask
RBob.
Thanks for replying on a Sat.
Ummm... Sure. How do I check for fragments and which mask?
I think it would be easier, now and in the long run, if I simply were to take the AXCN and convert my Flags, Constants, and VEs to the AXCN, and make it my own... right?
I also changed the cylinder volume size to reflect my BBC(402). I had to do that with the Howell bin anyway.
Most everything is the same with the Howell and the AXCN bins. Even the injector flow-rates are the same!?!?!?
I simply converted the VEs to my calculation 108/128 x [AXCN VEs] and it's pretty close! I get ~ 128 - 134 BLMs.
As it was before, even when I first got the Howell BIN, the AEs and PEs were wrong anyway (pretty close to stock with some weird stuff numbers in the upper temps).
86White_T/A305
Mar 6, 2016 01:48 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Twilightoptics
Dec 8, 2002 10:00 AM
deadtrend1
Car Audio
Feb 1, 2002 11:44 AM
