Im in a Jam HELP
Car: 86 IROC
Im in a Jam HELP
Ok i have a 85 Z28 its got a 350TPI in it running a 165 ECM and MAF the previous owner destroyed the TPI setup threads a stripped plenum is all cross threaded its pretty much junk.... i was given a TPI set up out of a 92 SD 305.
I need to put this on my car because the motor is just sitting with a plastic bag on it outside under my hood. i know i need to reuse my injectors from my 350 setup my other problem is the 9th injector if i use the entire 92 setup cant just leave it like it is, i do not have the equipment to program my own chips is there any other way of getting rid of the 9th injector in my ECM. Can i get an aftermarket chip (i know its not worth it this is just to get the car running) or can i grab one outa a 89-90 MAF car where there is no 9th injector... or can someone just help me out and burn me a chip i know im not suppose to begging i just dont want to lose the 4grand worth of motor work that i just had done.
thanks matt
thanks matt
Car: 86 IROC
Im replacing everything lower intake, runners, plenum and fuel rails... i mean this guy hacked up every thread on this thing... so i need a 89 non VATS chip??? sorry kinda clueless with this stuff
will a crappy hypertech chip work?
also will the car even start with the CSI unplugged?
Car: check
Engine: check
Transmission: check
It is well worth learning how to tune by buurning your own PROMS.
RBob.
QwkTrip
Nov 12, 2001 03:44 AM
