Timing Table..
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Timing Table..
Anyone see any issues with this, or concerns? Seems to keep me outta knock, but its really low.
<img src = "http://members.cisdi.com/~anesthes/730-scans/timing.jpg">
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
75 and 80 kpa areas look outta whack with the timing rising from cruise to part load/acceleration conditions...
May cause u issues with tip in knock , u r boosting this setup correct?
the WOT stuff still looks a little high, but then again I'm not there to see it...
Always ere on the low side and work higher....
U may be able to bring your cruise area timing up some and ramp it out a little more quickly and smooth out the aforemnetioned areas some...
Later
Jeremy
Later
Jeremy
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Thanks!
Car: An Ol Buick
Engine: Vsick
Originally posted by anesthes
Hrmm. I figured teh ramp up in timing would help accel.
Yeah, 20d is the highest I seem to be able to run without knock. I used to get away with 27d with the a-trim (8ish psi).
20 is about all you'll want to run in boost.
The idea is running the least amount of timing consistant with max performance.
For a boosted engine you want to keep the chamber temps down more then in a N/A application, so running a low timing set is best.
