Where are Fuel Tables??
Old Apr 29, 2004 | 02:36 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Where are the fuel/VE table in TunerPro? For some reason I can't find them. Are they called something different?
Old Apr 29, 2004 | 03:12 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
There aren't any VE tables in a MAF-only system. You need to use the MAF tables and scalars instead.
If the '85 code is similar to $32 and $6E, there'll be 6 MAF tables, that go from low to high MAF output.
Basically, if you go to a particular point in a table, and make the g/s value higher, you'll get more fuel at that point, and vice-versa.
Should be a couple of sticky posts worth reading, including Grumpy's "final answer" about MAF recalibration.
Old Apr 29, 2004 | 03:53 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
this is a quote form grumpy that I find to be helpful
and check out Grumpy's final answers like Dave_Jones recommended they are very informative.
Originally posted by Grumpy
If you want to get the car happy, and running great, it's really simple.
Set the injector constant for what the actual injectors your running.
Get a WB.
Set the chip to stay Open Loop.
Diddle with the MAT tables till you get the AFRs you want. The Stoic stuff is nonsense.
http://www.gnttype.org/techarea/chips/chiptips.html
Here's my latest MAF stuff.
Old Apr 29, 2004 | 04:13 PM
Dave_Jones's Avatar
Just a note on the quote above, where he says "MAT tables" is no doubt a typo; I'm sure he meant "MAF", not "MAT".
Old May 1, 2004 | 03:31 AM
GMH_VQ's Avatar
Car: Holden VQ Statesman
Engine: 5.0L V8
Transmission: 5sp Manual, IRS
How sad that the Turbo Buick forum is about to/or appears to have gone down while I was browsing it. According to it's home page- perhaps indefinately.
I wish I could afford to help.
forumhttp://www.gnttype.org/techarea/chips/chiptips.html
Sean
Old May 1, 2004 | 01:38 PM
Dave_Jones's Avatar
Yup, the owners pulled the plug last night. They're going to take some time to migrate things over to a new server, and do some other upgrades. But, it'll back.
Azrael91966669
25
Jun 20, 2017 04:04 AM
fasteddi
Sep 2, 2015 10:29 AM
htrdbmr
Aug 18, 2015 12:58 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
