Max idle in drive
Old Apr 29, 2004 | 06:59 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Max idle in drive
I know this has been posted about before, but other than in the SUPER AUJP post i can find no mention of it..
Basically its to raise your in gear idle speed over the 800 rpm limit
Anyone else have any more info?
thanks
Jeremy
Old Apr 29, 2004 | 08:34 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Max idle in drive
thanks
Jeremy
Yes, the old max idle in drive trick. Spent way too much time looking for it in ANHT & AXCN, and not finding it. Then after Trax posted the AUJP locations for it I discovered that it only exists in f-body bins. The y-body $8D bins don't have that 'feature' in the code.
To make things more interesting I checked four $8D bins, two f-body and two y-body, one auto and one stick each and found that none of the four matched code-wise any other.
From what I could tell the calibration table locations matched, but there were code differences.
I've found the same with $88 mask and $A1 masks. Same cal table locations, with code changes over the years. Interesting. . . then the $32 & $32B stuff. . . Crazy I tell you, just crazy. . .
RBob.
Old Apr 30, 2004 | 02:26 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
To give proper credit where credit is due ...
Scot Sealander shed light on it for me. I did my best at the time to track it down and spent tons of time pouring over the stuff. I was in the right location ... but I just couldn't read the code right. Scot pointed it out to me and showed me that it was right in front of me. Yet another situation where someone had to make sense out of a piece of assembly I was looking at.
Tim
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
gta90
Sep 15, 2015 04:00 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
