$61 VE2% table
Old Apr 30, 2004 | 12:28 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
$61 VE2% table
I read a couple of threads that talked about actually zeroing this table out in the $61 code. I was wondering if I could simply add these values to the VE%1 table in my BIN and then zero out the VE%2 table. That way, I could tune using only the VE%1 table.
Is this a good idea or will it end up breaking something?
TIA!
Old Apr 30, 2004 | 12:55 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Don't do it. If you do there will be no way of reducing the VE as the RPM increases past the peak torque.
RBob.
Old Apr 30, 2004 | 01:06 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
'Nuff said. Thanx, Rbob. It stays as it is.
Can I change the values in the VE2% table? I mean, is it okay to change them? I have just about done enough to the VE1 in the lower RPM/MAP ranges. I think that if I take much more out of it, I may end up with an overlean condition. My lower end VEs are already in the mid teens.
Old Apr 30, 2004 | 01:35 PM
JPrevost's Avatar
Car: 91 Red Sled
I keep the 400 to 3200 rpm constant at 30 so when I look at my VE1 it looks normal. By keeping 30 in those area's of the VE2 you can then take out some fuel after peak torque by as much as 30, I've found this to be easiest so again, don't zero out the VE2 .
Old Apr 30, 2004 | 01:37 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
So basicall, I can put something that works (like 30) in that table from 400 to 3200 and use the VE1 to control it? My engine sees peak TQ at about 4000 rpm. I can start pulling fuel there?
Old Apr 30, 2004 | 02:32 PM
JPrevost's Avatar
Car: 91 Red Sled
Yeah. So anything past 4000rpm should be less than 30 in the VE2 table. That's how you get it to "curve over" with these compound tables. I personally hate it but I've learned how to deal with it. I understand why GM did it too but it really is hard to visualize when just looking at one table or the other.
Old Apr 30, 2004 | 03:10 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
You can make 20-30 passes to figure it out, or 5 mins on an ecm bench.
Say your table looked like this
45
45
45
45
45
45
45
45
35
30
20
You could subtract 15 from, all the values in the VE2 table, and then add 15 to all the VE 1 table entries.
Rough in you VE around the peak torque area, and then just spin up the bin on an ecm bench to see where EXACTLY you are. Then you can in 1-2, maybe 3 passes see where you are, fuel wise.
Old Apr 30, 2004 | 03:41 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Gotcha! Thanks gents! Beers to all!
Too bad I don't have and can't afford an ECM bench right now.
Azrael91966669
25
Jun 20, 2017 04:04 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
