blm numbers
Old May 9, 2004 | 06:30 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
blm numbers
Hey guys,
I'm trying to use tunerproRT and looking at my datalogs it says the integrator is 128, but the blm is 160. this means very rich.. right?
Old May 9, 2004 | 07:05 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
If your BLM is at 160 you are running SUPER LEAN.
Old May 9, 2004 | 08:24 PM
mmcdjs's Avatar
Engine: 3.1 V6
lean? that's got to be a sensor problem ... I have flames shooting out of my exhaust manifold.. how can that be lean?
Old May 9, 2004 | 08:45 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Your O2 sensor could be on the way out!!!
Old May 9, 2004 | 09:05 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
You are running it without pipes? How can you see flames coming out of the exhaust manifold? I did that with my 360...ONCE years ago when I first put the 360 in the Jeep. It set fire to the grass under the Jeep. I haven't done it again since. Regardless, you are probably gonna see some flames out of the manifold flange without a pipe on it.
Anyway, if you don't have a pipe on the thing, it seems to me that you may be getting some air drawn back into the manifold as the exhaust pulses kinda draw back into the flange.
If you do actually have a pipe on it, then I am a jackass and all of this is N/A.
EDIT: What ECM/mask are you running? I have an 8746 and my max BLM is 150.
Old May 9, 2004 | 09:06 PM
mmcdjs's Avatar
Engine: 3.1 V6
ok. while I try to tune this thing, and stop the flames, is there a way to disable the o2 sensor and keep my blm at 128?
Old May 9, 2004 | 09:08 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Won't do you any good. You can run it in open loop, but then in my understanding of it all, you aren't tuning the closed loop VE stuff. The BLM will sit at 128 in O/L I think.
Old May 9, 2004 | 09:22 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Unpluging the O2 will disable it, then just unplug the battery for 30 sec to clear the ecm memory. See if this helps.
Old May 9, 2004 | 10:08 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Wouldn't that give meaningless BLM data...if any data at all? It would go closed loop, but would the ECM have any idea where to set the BLM or INT?
I agree that if the exhaust is set up right it sounds like the O2 sensor may be on the way to the trash can.
Old May 9, 2004 | 10:55 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
The ecm would make no corrective action, but if it runs better with no O2 installed then shes a bad sensor, or wrong tuning.
Old May 9, 2004 | 11:03 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
With a stock BIN, I would lean to the bad sensor...but we know that the stock BINs aren't the greatest. So...where does that leave us? Since he is tuning it, maybe he really IS that lean, but I don't see how unless the chip burn got screwed up or the correction to the VE was just really wrong...BLM of 160? I've seen 131 and that is the highest I have yet seen that I recall. Does the ECM scale the BLM value to the overall scale provided (max and min BLM) in the BIN?
Old May 9, 2004 | 11:44 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Yes the ecm will go to the max and min values, if thats waht it takes. Now the reason there is max and min values is so the ecm doesn't falsely over compensate due to a bad sensor.
Old May 10, 2004 | 12:01 AM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
I was kinda asking if the ECM would change the swing point from 128 based on the max and min values. That might be worth an experiment or two. You could use O2 voltages as a comparison point. Say your O2 swings at 0.450V and 128 BLM. Change the MAX and MIN BLMs and see if the new BLM swing point moves in relation the the O2 swing point of 0.450V.
Old May 10, 2004 | 09:08 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
U know, dumb idea here. Before u go chasing stuff, reverify the bin u loaded and that it is setup properly. Pull it and read it to verify.
I know a guy here who loaded a bin for his Formula up instead of one for his GTA(next to stock) it ran very lean for some odd reason :-)
later
Jeremy
Linson
Oct 24, 2025 02:00 PM
Mark_ZZ3
May 24, 2018 01:02 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
