MAP interchange?
Old May 21, 2004 | 04:33 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
MAP interchange?
Will a MAP from a TBI F-body or truck (88-95) interchange with a SD TPI setup (90-92)? Or is there something different in the electronics? I assume GM Map sensors...
I would like to temporarily swap the MAP from my 94 suburban to test my MAP on the 91 Camaro.
Thanks!
Old May 21, 2004 | 05:18 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: MAP interchange?
Thanks!
Most likely will swap. Look into the connector portion of the MAP sensor. If black or green will interchange. Hot stamped number will be 039 or 460. Found on top surface above connector.
RBob.
Old May 22, 2004 | 01:06 PM
Engine: LS3
Transmission: 6L80E
Thanks..I will check that out!
aaron7
Sep 30, 2015 09:15 AM
tuningnewb
Sep 23, 2015 07:06 PM
ULTM8Z
Sep 16, 2015 09:15 AM
sbrandon
Sep 9, 2015 07:31 AM
