vss question
Old May 21, 2004 | 09:09 PM
scottydta's Avatar
Car: 1989 Trans Am
Transmission: 700R-4
vss question
switched from a 6E tune to a 32b because of its ability to specify injector pulse widths. now i'm throwing a code 24 every now and again. does an 88 tune use the vss signal? put a new vss in cuz it had over 100,000 miles on it anyway but its still coming up. anyway to disable it in the tune? the computer is an 89 unit. using an 88 vette bin. comments? suggestions?
Old May 22, 2004 | 02:28 AM
Morley's Avatar
Wouldn't advise disabling the VSS in the ECM (nor just the VSS fault code) You need the VSS for T/C lock up.
I have run my car on both the 32b & 6E codes (along with the original 870 chip/ECM) with the same VSS in place and never had it throw a code.
I would go back to the 6E code (temp) and see if the problem is there now too. If it isn't have a look at both .bin's in any area dealing with VSS input. If the 88 bin is different than the 6E, change it to the 6E's settings and see if that cures the problem. It may just be that the 88 code is intolerant of a variation in the VSS signal your car is producing and needs the parameters changed a little.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
