WB-o2 datalogging
Old Jun 11, 2004 | 12:07 AM
elohssa's Avatar
Car: 1992 T/A convertible
Engine: LB9
WB-o2 datalogging
I've been reading up on all the info regarding patches for getting WB-o2 data into the ALDL stream and I can see that it is very valuable for tuning, However all the info is geared toward the DIY-WB setup, I have an innovative LM-1 will this work with the patched bins that exist or is the output from it different than the DIY-WB?
Old Jun 15, 2004 | 11:51 PM
Kevin 88's Avatar
Car: 88 Corvette
Engine: 400, AFR heads, ZZ9, SuperRam, 730
Transmission: Slushbox
Thanks to 91L98Z28, I use my LM-1 with his patch, with great results:
https://www.thirdgen.org/techbb2/sho...hreadid=212587
The pic shows how I calibrated the output of the LM-1.
This is all for $8D though, I don't know about your ECM.
Old Jun 16, 2004 | 09:12 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Anyone tried outputing the analog out of the LM1 to MAF (165) ecm? I have the LM1 and noticed the ease of programming that output to anything that you need. I got to get that output wired to my ECM and just try it.....supposed to log thru the commanded AFR parameter...but i don't have that on my scan tool., just something called "total fuel/air value".
Also heard folks logging the info thru other (unused) inputs in the ECM.
I really need to cracking at this, othewise hard to compare the LM1 log data to a scan tool data record.
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
ezobens
Aug 19, 2015 10:29 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
