maf tables
Old Jun 16, 2004 | 03:56 PM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
maf tables
i just started tunning my car and i have the BLMs close to 128. at idle its around 130.. but i had to mess with the maf scalers ALOT to get it close i had to increase the first table a good 20 points.. this is with 30lb injectors.. i've read you're not supost to mess with the maf tables alot. but it seems to be the only way to get the blms close to 128 besides butchering the injector constant?
and at 2000rpm tunerpro is showing 14.00 grams is that normal?
Old Jun 16, 2004 | 06:01 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: maf tables
At one time they weren't very well understood, and it wasn't suggested to play with them. Times have changed since then.
If you're running close to 128s, you're fine.
The more important guestion is how's it running?. Good/fair mileage, temps reasonable, etc..
Old Jun 16, 2004 | 06:25 PM
level's Avatar
Car: 1987 transam
temps stay around 200 i have the fan on set to 200 and off set to 195
very poor gas mileage
sorry i can't post scanner logs my laptop doesn't have a eithernet card.. so its sorta hard to network it.
EDIT: one important thing i noticed in tunerpro is that the Intergrator (INT) would drop to 50 and turn red at times? none of the n00bie articles really said anything about intergrator.. so i really have no clue what it does?
and as i get closer to 128 at idle the car doesn't want to idle at all. i have to peddle it to keep it going for about 40 seconds then the idle stabilizes?
i was reading that some larger injectors need a shorter pulse width would it be wise to uncheck the calculate bpw and set it manually to 45/40?
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
ULTM8Z
Sep 16, 2015 09:15 AM
