TunerPro $8d BPW
Old Jun 18, 2004 | 09:41 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
TunerPro $8d BPW
Hey,
Is anyone else getting odd injector base pulse widths while logging with TunerPro RT? I have stock injectors but the highest pulse width I'm seeing is 0.1msec. I know this is wrong though. From what I've been able to determine it is outputting the inverse of the bpw. Anyone else have this problem? I've emailed Mark and he isn't sure what is wrong.
Thanks,
David
Old Jun 18, 2004 | 10:03 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
you didn't mention 0.1 ms! Sounds like the issue is the ads file. Make sure the math is being done correctly. The factor for BPW is generally 0.015259 (and it should be set to multply).
Old Jun 18, 2004 | 11:00 PM
Thanks that seemed to fix it! It was set to divide with a factor of 65.xxxx. Though I didn't set it
Do you know the correct setting for the TPS% as it seems off too?
Any idea when you'll get the into to editing ads files written? That way I can stop bugging ya.
Thanks!
antman89iroc
Oct 1, 2008 07:25 AM
yorkshirespud
Jan 6, 2008 06:58 PM
88tpiolds
Sep 17, 2006 09:41 AM
cormyr
Aug 10, 2004 11:00 PM
