Calc BPW (Don't use Table) in TunerPro
Old Apr 28, 2008 | 09:19 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
"Calc BPW (Don't use Table)" in TunerPro.
Does anyone know what this flag does? I've noticed that it's checked in some bins and not in others.
The ones it's checked in don't seem to run as well as the ones it's not checked. But since I don't know what it does, I can't decide if it's causing the effects I'm observing.
Old Apr 28, 2008 | 11:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Calc BPW (Don't use Table) in TunerPro
In $6E it is a dead flag. Doesn't do a thing.
In $32 it decides whether the code looks up the injector PW from the LV8/RPM table. Or from a calculation based on MAF airflow.
RBob.
Old Apr 28, 2008 | 11:24 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
So does $6E use the LV8/RPM table, or does it use the MAF airflow?
Old Apr 28, 2008 | 07:45 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Good question, to calculate the PW it uses the MAF airflow and injector constant ($6E).
RBob.
Old Apr 28, 2008 | 09:05 PM
mnorton's Avatar
Engine: 305 LB9 TPI
RBob.
Oh I see. That's probably why a descreened MAF needs to have the MAF tables modified... but wait, that seems to indicate that $6E would be the only good option ($32 verses $6E) for for tuning with a modified MAF sensor....
Old Apr 29, 2008 | 08:01 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not really, both $32 & $6E can/will use the MAF airflow & injector constant to calculate the injector PW.
And, LV8 is a calculation based on MAF airflow, engine RPM, and a displacement scalar. So using the PW table still depends upon the airflow measurement from the MAF.
RBob.
Old Oct 1, 2008 | 07:25 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
RBob.
So in this equation the displacement scalar is 80?
LV8 = ((((983040 / RPM) * gms/sec) / 256) * 80) / 64
Would this need changed, for a larger displacement motor?
Azrael91966669
25
Jun 20, 2017 04:04 AM
beast94
Aug 20, 2015 06:44 AM
tmellott89
Aug 16, 2015 02:58 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
