LS1 25# Injectors And Fuel Mileage
Old Jun 24, 2004 | 11:55 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
well guys i have a couple of questions for you guys with the LS1 25# injectors. have any of you noticed a drop in fuel mileage? i was looking at the stock AUJL bin and Highway Mode is enabled by default on $6E. this could cause a major loss of MPG do to highway modes open loop operation + the larger injectors running on a stock bin. i used to get pretty decent mileage with my stock 22# LEAKING injectors but it runs a hell of alot better now with a loss of MPG.
i was running it with highway mode on for a while and have turned it off for now. i have turned off highway mode since having it on (atleast with the stock bin) was causing a loss of MPG correct?
well i have everything pretty much dialed in where i want it on my $6E. granted tuning was done with the almighty butt dyno and track runs. only fueling on the bin i have played with is the startup fuel, injector constant set @ 24.94# and PE mode. now i really want to bring the MPG back up and beyond stock. i have the base timing set @10*. all sensors/solenoids have been replaced AIR system is intact and fully functional. also EGR is in good working order.
what tables and/or constants have to be "trimmed" in order to compensate for the larger 25# injector. what is the best way to get the MPG back? all suggestions are welcome.
Old Jun 24, 2004 | 12:08 PM
Car: 1988 IROC-Z
previous mileage
city 17 - 19 MPG
highway 24 - 26 MPG
current mileage
city 14 - 16 MPG
highway **** that. the car uses too much gas to even try it.
please help!!!! my wallet is getting too light too fast.
Old Jun 25, 2004 | 08:58 AM
Car: 1988 IROC-Z
well i guess i'm the only one with these problems then.
i guess i'll buy a ALDL cable, laptop, and get some blm readings.
Old Jun 25, 2004 | 05:01 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Basically you hit it on the head. I don't know anyway of doing it with out feed back to know where you are.
I see you have to adjusted your injector constant for the larger injectors. This may bring it closer to the proper tune, however with out the data, you may still be too rich, thus using more fuel than needed.
Old Jun 26, 2004 | 08:59 PM
Car: 1988 IROC-Z
i just finished an expensive upgrade on pc today. hence my late reply. i'm working on it.......
Azrael91966669
25
Jun 20, 2017 04:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
