maf to map knock sensor question
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
i am sick and tired of having maf related problems like a never ending code 34 that i can't fix and neither can anybody else in the world. So i was reading mike davis's site and a swap to sd is sounding nice.
Can i just replace my knock sensor with a 92 knock sensor? Or once i do that do i also have to jump the two terminals in the esc harness.
Car: check
Engine: check
Transmission: check
For a MAF to SD conversion need the '92 knock sensor and to remove the ESC module and jumper the two pins together.
On a SD system (TPI/'7730) the ESC module is on the MEMCAL.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Originally posted by gta_88_kicks
the two pins in the esc connecter right?
RBob.
