big timing jump W/ temp - normal?
Old Aug 13, 2004 | 11:30 AM
88TAJeff's Avatar
Car: 88 T/A
Scanning my car this morning W/ moates, I notice 15 deg adv , until temp hits 124, then shoots up to 30 deg at idle and stays there. Is this normal?
TIA, Jeff
Old Aug 13, 2004 | 09:23 PM
88TAJeff's Avatar
Car: 88 T/A
No-one?
I don't recall this being the case anytime I checked the timing. I'm chasing a code 42 recently and could use the insight. Thanks
Old Aug 14, 2004 | 07:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by 88TAJeff
No-one?
You will need to fix the code 42 problem first. That is a DRP error and will typically lockout ECM control of the timing.
RBob.
Old Aug 14, 2004 | 01:56 PM
88TAJeff's Avatar
Car: 88 T/A
RBob, Thanks for the reply. The code 42 is gone now; what would happen is the car would run for awhile and then die: no spark. So I took a look at the dist. module ( 1 year old) and it had some rust on the screws and housing. cleaned it up, and now it runs again, but with this funny cold / hot timing thing. It's an aftermarket module, btw.
Fanatic1074
Oct 3, 2022 05:57 AM
sheachopper
Jul 31, 2019 11:27 AM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
