'7747 Commanded AFR vs BPW vs VE's
Old Aug 16, 2004 | 05:57 PM
ben73's Avatar
Guys,
I would like to bring my commanded PE AFR into line with what the WBO2 is showing. Currently the PE AFR tables are at 11:1 to give 12.8:1 at the WBO2.
Are the VE's independant of the commanded AFR calcs? ie., Can I adjust the BPW constant to bring the actual AFR closer to commanded AFR without having to remap the VE's??
TIA,
Ben.
Old Aug 16, 2004 | 07:59 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
The fuel calc for PE is based off your VE tables, which are based off bpw,
I would add fuel to your VE table in the high rpm/ high map areas to make your PE afr match your WB
ULTM8Z
Oct 2, 2015 01:25 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
355tpipickup
Sep 28, 2015 05:50 PM
tuningnewb
Sep 23, 2015 07:06 PM
355tpipickup
Sep 13, 2015 11:35 PM
