Will not idle worth a crap with 32B chip, but idle much better with ARAP chip, why
SubscribeI installed a 395 cu in stroker and am having major problem with idle.
The engine will not idle with a 32B ECM Eprom, but will idle much better with the 6E ECM ARAP Eprom.
Can someone explain this to me? Whats going on?
I did throw a 31 error code with the ARAP Eprom, its not in my book.
ERR 31= Canister Purge Solenoid fault, EGR circuit fault , Map sensor circuit shorted,Low voltage, Fuel Injector fault or park neutral switch/governor malfunction.
This is what it says in my info.
Just my .02
Just my .02
I checked the fuel pressure with the engine running, so I disconnected the vacuum line the the AFPR, maybe that is why I set the 31 error code.
I'll disconnect the negative terminal to reset the ECM.
Then if the engine still idles better, I will do the IAC adjustment, set idle RPM, and check the static timing.
