MAP conversions in $58.ECU file
Old Aug 19, 2004 | 05:12 AM
SABLT194's Avatar
I'm working with a $58 ecu file in Tuner pro. Seems like all of the MAP conversions are kind hosed when compared to Promgrammer. Anyone have the correct math on these?
Thanks much
Steve
Old Aug 19, 2004 | 06:19 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: MAP conversions in $58.ECU file
Which table(s) do you mean?.
Old Aug 19, 2004 | 02:16 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
How far off are they? Doesn't Promgrammer show you the math used (bin a bit since last I saw Promgrammer)?
Old Aug 19, 2004 | 04:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
When you mention a $58 ECU file, which one is it? Do you have a filename?
(wondering if it is the one I did. . .)
RBob.
Old Aug 19, 2004 | 07:50 PM
SABLT194's Avatar
I'm looking at the PE enable stuff like:
Power Enrichment Threshhold
Primary MAP Threshhold
Secondary MAP Threshhold
The ECU file I'm using is file name 58.ecu (pretty clever huh). I'm not sure where it originated but it is very complete
The MAP conversions are as follows:
MAP= Value * .369004 + 10.35
Promgrammer does not show calcs AFAIK
Steve
Old Aug 20, 2004 | 06:48 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Steve
I believe the above conversion is correct. That is used to convert from an ADC 1 bar MAP term to KPa. Which is the variable used for those parameters. When running a 2-bar MAP sensor this term is converted to a 1 bar value.
This is something that I would typically verify on a test bench, but alas, I don't have one set up for the P4's yet.
RBob.
Old Aug 20, 2004 | 07:42 PM
SABLT194's Avatar
Here's what i figure the calculation to be in Promgrammer:
8 + Value * .781176
I set hex to 00 and Promgrammer returned MAP value of 8 KPA.
Set Hex to FF and Promgrammer returns 207.2 KPA
This is with the 2 bar MAP bit set (don't know if that makes a diff)
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
aaron7
Sep 30, 2015 09:15 AM
