key on 3rd gear request/limp mode start
Old Aug 28, 2004 | 07:49 AM
sparks454's Avatar
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
I got tunerpro working, hallelujia!!!! The issue now is that there is TRUE for 3rd gear flag with the key on. I am pretty sure this is why the car is starting in limp mode. '87 t/a 165 ecm and 6e ARAP bin...What might cause this??
Thanks,
Chris
Old Aug 28, 2004 | 01:05 PM
sparks454's Avatar
Car: 1987 GTA
burned the chip with the original unaltered ARAP bin with no luck,,,tried another ecm with no luck. tried starting the car with electrical connector on the side of trans unplugged with no luck...Used the old hypertech chip with no luck....any idears...anyone...anyone..
Old Aug 28, 2004 | 01:47 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Pull the pin at the ECM connector to check if there's a short in the wiring harness somewhere. A short would still show up with the trans unplugged......
If you don't have a wiring diagram for the car get one, you'll need it. In the meantime PM Trickster or post on the electronics board, he's always putting wiring diagrams up for people.
Old Aug 29, 2004 | 09:29 AM
SBNova's Avatar
So when you say you got tunerpro working does that mean you are able to scan? Im just curious- what did you find wrong? Cable,prom,computer config.????
Old Aug 29, 2004 | 12:40 PM
sparks454's Avatar
Car: 1987 GTA
It appears that there was nothing wrong. It was just a matter of getting the program to connect. Usually takes me about 10 times or so and all this while trying to reload tunerpro, unplug and then plug the cable in...what a pain. I like to program, but it's really hard trying to get it connected. It looks as if there is no specific order of plugging in the cable and relaunching the program...
Chris
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
tnrednneck
Aug 13, 2015 08:57 AM
mizz0313
Aug 12, 2015 06:45 AM
