Unable to BIN edit with TunerPro,730 ECM
Old Sep 7, 2004 | 03:22 PM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
Transmission: TCI 700R4
Axle/Gears: 12 bolt with 3:73's
This prob. just started.
I'm trying to edit a stock AUJP BIN.Trying to get the VATS out.
I open TunerPro and click "File" then "Open BIN".
I double click the S_AUJP_V2 Bin,then click ECU.Then select ECU.
I double click Super_8dm2-1.ecu
Now...TunerPro is suppose to list all the "Constants","Flags" and "tables"
For some reason it will NOT do this.Nothing comes up to edit.
What am I doing wrong?
I just install my Prominator and sucessfully uploaded the stock BIN.The prob. is that BIN has Vats.Again,that's what I am tryi g to edit.
Old Sep 7, 2004 | 03:35 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Try the "view" pull down menu, or F6, F7, and F8 keys.
Old Sep 7, 2004 | 06:15 PM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
Nada...Same thing.Still nothing to edit.
Thanks though.
Old Sep 7, 2004 | 07:51 PM
Dave_Jones's Avatar
Are you seeing the Constants, Flags, and Tables boxes? (should pop up when you hit the F6 key)
If you've got those, double click on a line item, and another box should pop up, that allows you to alter that item.
Old Sep 7, 2004 | 07:59 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
You've got mail !!
Maybe try to uninstall and re-install tunerPro.
Or could just be the downloads got corrupted somehow.
I don't know, never had that happen.
Jp
Old Sep 7, 2004 | 08:44 PM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
The boxes are there...just nothing in them.
I'll try reinstalling,see if that works.
Old Sep 7, 2004 | 08:56 PM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
Here...this is what I get.
Attached Thumbnails Unable to BIN edit with TunerPro,730 ECM-screen-shot-tunerpro.jpg
Old Sep 7, 2004 | 09:24 PM
Dave_Jones's Avatar
Those boxes should have "stuff" in there, even if a .bin file isn't open. How about trying a different 8D ecu file?
Old Sep 8, 2004 | 01:16 AM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
I've tried a couple different ECU files as well as different BIN's.
I removed the old program and install TunerPro again from Marks site.
The result is the pic you see above.
Old Sep 8, 2004 | 03:27 AM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
Played with it for a while and still nothing worked.
I erased my currant copy of TunerPro and downloaded the most currant version.
Works now.
Problem solved
I want to Publicly thank A member named JP.
He saw this post and took the time to edit a stock AUJP Bin for me and sent me the BIN via e-mail.
I thought that was pretty cool of him
Thanks man.
I took a look at the BIN he sent me then I loaded up the S_AUJP BIN.
I was able to edit it and took the VATS out from that BIN as well.
We'll see how it works in the a.m.:rockon: :rockon:
Old Sep 8, 2004 | 07:53 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
glad you figured it out. the original ECU file you were using was invalid.
Old Sep 8, 2004 | 09:57 PM
JP86SS's Avatar
No Problem, I know there's nothing worse than having everything ready just to be stopped by VATS!
Glad you got your stuff working.
Did you get it fired up?
Old Sep 9, 2004 | 08:50 AM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
I sure did.Thanks again JP.:hail:
Not running that great though.
TunerPro is seeing TPS voltage of .04
I have to check my wiring as this was a preexisting condition before I ever installed the Prominator and the S_AUJP BIN.
I think I might have a short to the ECM as the TPS tests out fine at the sensor...5V in,Good ground and .54V out at idle.
I'm also throwing a code 22= low TPS voltage.
Before the Prominator install I was seeing readings of 25V for TPS voltage(impossible,I know).That's with the TunerPro software .
Anyone have a link to a 730 ECM pinout?
Mark,I just noticed the ECU file name on my orig. screenshot.I must have renamed that file somehow.
No wounder nothing popped up
Old Sep 9, 2004 | 10:56 AM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
For some reason it took me a while to find those pinout schematics
Found them HERE
Old Sep 9, 2004 | 11:13 AM
Mangus's Avatar
Transmission: T5WC
Verify that the TPS item in the ADS file is doing the math correctly (correct factor, etc).
Old Sep 9, 2004 | 11:14 AM
JP86SS's Avatar
I sent you a copy of my wiring diagram.
That will help you out graphically to trace things down.
Good luck.
Jp
Old Sep 9, 2004 | 11:51 AM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
JP thanks for the diagrams!
Mark,here's a screen shot of my TunerPro's settings.
Old Sep 9, 2004 | 12:40 PM
Mangus's Avatar
Transmission: T5WC
That looks correct.
Old Sep 9, 2004 | 05:29 PM
JP86SS's Avatar
More for Magnus,
While I looked at that screenshot I had a question.
If the alarms are enabled, do they flash a message or indicate when the limit is exceeded?
Just wondering, never turned them on to see.
Neat feature if so.
Old Sep 9, 2004 | 05:34 PM
Mangus's Avatar
Transmission: T5WC
If alarms are enabled, they change the text color of the item from black to red whenever the value is above or below the alarm threshold.
Old Sep 9, 2004 | 06:28 PM
JP86SS's Avatar
Neeto!
I'll have to play with that.
Great job.
$750 L98
Feb 1, 2025 02:25 PM
Mark_ZZ3
May 24, 2018 01:02 PM
thunder57
Nov 7, 2015 02:28 PM
ULTM8Z
Oct 2, 2015 01:25 PM
efiguy
Sep 27, 2015 01:30 PM
