Simple Question values in Tunerpro
Old Sep 8, 2004 | 10:02 PM
IroczInOz's Avatar
This is probably a simple question and a stupid one but I want to ask it anyway.
Since I have a table made up in excel to automatically calculate NEW VE values when the old values are pasted in on one side of the table.
Since the new values could be anything like for example my new VE value is to be 45.45. In tunerpro you can't get that vaule to show up either 45.31 or 45.70 when you press the + to go up in values.
So what happens if I paste in the value 45.45 will it adjust itself to the closer value (45.31) or will it in fact stay at 45.45?
Old Sep 9, 2004 | 01:40 AM
ben73's Avatar
It will change it a little bit.
Its because they are 8 bit numbers, which means that the range of decimals (probably 0-50 degrees in this case) can only be represented by 255 different numbers..
Old Sep 9, 2004 | 08:41 AM
IroczInOz's Avatar
Cool so no problems just pasting them in sweet
Old Sep 9, 2004 | 07:11 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Correct. If you paste in a "middle" value, when you go to save the item (table/constant) in TunerPro, TunerPro will round the number you entered to the nearest possible value.
Ben is correct - this is a resolution issue.
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
tmellott89
Aug 16, 2015 02:58 PM
camaroken83
Aug 10, 2015 11:35 AM
