Out of fuel again.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Out of fuel again.
Out of fuel again! Guess I'll be shopping around for some 42# injectors.. Heres a small snip from messing around. The setup is
a 355 cid, vortech S-trim with a small pully (about 10-12psi at 6k), 36# injectors, and about 60psi under boost.
<H5>
<PRE>
MPH RPM TPS % O2 mV BLM AFR Spark Retard Adv Real Inj BPW Inj DC MAP Boost Knock IA Temp IAC Pos
44 3850 60 799 129 11.8 12.7 0 22.5 8.33 53.5 113.4 2.2 9260 108.9 8
49 4025 76.9 817 129 11.8 12.3 0 22.2 15.5 104 131.4 4.9 9260 108.9 8
51 4300 100 830 129 11.8 14.4 0 24.3 10.01 71.7 140 5.9 9260 108.9 8
55 4550 100 808 129 11.8 14.8 0 24.6 10.5 79.6 145.5 6.6 9260 108.9 8
58 4900 100 804 129 11.8 15.1 0 25 11.35 92.7 150.9 7.6 9260 108.9 6
62 5275 100 830 129 11.8 15.8 0 25.7 11.9 104.6 157.2 8.5 9260 108.9 6
67 4850 100 0 129 11.8 14.8 0 24.6 11.11 89.8 149.4 6.5 9260 108.9 6
56 4775 100 0 129 11.8 15.5 2.3 25.3 10.86 86.5 149.4 7.7 9323 108.9 6
</PRE>
</H5>
Injectors go static at about 5k, and o2 drops from there.
-- Joe
<H5>
<PRE>
</PRE>
</H5>
-- Joe
Car: 1987 Z28 Convertible
Transmission: 5-speed
Joe,
You might want to consider these from Summit:
Mopar Performance Injectors
P/N: P5249452
52lb/hr @ 55-psig
Clint suggested these to me and I have ordered them. They are low-z injectors.
P/N: P5249452
52lb/hr @ 55-psig
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by Willie
Joe,
P/N: P5249452
52lb/hr @ 55-psig
Joe,
P/N: P5249452
52lb/hr @ 55-psig
Thanks for the info. Taking it under consideration..
Hows the car?
-- Joe
Ouch! $367.92..
Yes, but you'll probably never need another set and you can offset the cost by selling your 36#ers....
Hows the car?
Don't ask....>>
https://www.thirdgen.org/techbb2/sho...hreadid=256875
Willie
Hows the car?
Don't ask....>>
Willie
Car: An Ol Buick
Engine: Vsick
There are 60 PPH high impedance injectors out there. I've been using them in my 3.8L without a hitch. With them, no ecm mods, and they'll make alot of HP. Kinda $$, but why not just do it right once?.
Won't such high flowing high-z injectors cause idle/low speed problems?
Willie
Willie
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Willie
Willie
So in theory, the ECM should switch when such large injectors are used.
But Grumpy would know better. So I'm awaiting his response.
-- Joe
Car: An Ol Buick
Engine: Vsick
Like I've said....
Well, thank you for saying again. It's kind of difficult to search and read about one person's experiences only to know that you've said this before, especially if you don't know who and what topic to search for!! Therefore, there is no way I could know of your experiences.
Where did you get the 60#ers??
Willie
Willie
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Mine came from Full Throttle Speed.
http://www.fullthrottlespeed.com
Some of the other vendors that cater to the Turbo Buick crowd carry them as well. Also, you'll occasionally see them advertised as 65's, rather than 60's.
HTH,
Car: 1990 Formula
Transmission: WC T5
Those 60 lbs ers are called high Z injectors.
The High Z are compatable with the stock TPI computer, correct?
Low Z are pulse and Hold?
How well does the car idle with this large of and injector (I would think that it is a mighty small pulsewidth), with computer adjustments of course.
Peak and Hold.
Car: An Ol Buick
Engine: Vsick
Originally posted by Dave_Jones
They're MotoTron injectors.
