ok guys giong to burn a chip this week end
Old Sep 16, 2004 | 10:39 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
ok what do you guys look at to get a chip ruffed in i was thinking of just going of the average blm for a 30 min cruze around town. take that table i get and adjust from there is this a good way to start or is there a beter way to start.
i am just trying to keep a open mind so that some one may teach me how they did it ya know some times things work better another way
Old Sep 17, 2004 | 11:54 AM
Morley's Avatar
I started with getting the idle BLM's as close to 128 as possible, then went for a drive to check part throttle and adjust as required.
Old Sep 20, 2004 | 10:44 AM
Ronny's Avatar
try and find a level road without much traffic. i started idle(neutral) then upped rpms till cells had data(neutral). then that log on level road with no unusual throttle activity trying to populate the other cells. after i got data in those cells and double checked on diff days i worked on the "odd" cells that did not populate. i dont recommened(!!!) but i disabled the AE/PE for the higher rpms/ higher MAP and finally got some data in those cells. other cells (high rpms/map)i guessed (enrichened) since did not populate all cells. dont forget to reenable if you attempt this.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NWAsonoma
Aug 18, 2015 05:45 PM
Street Lethal
Aug 14, 2015 08:25 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Exxon Limited
Aug 9, 2015 08:13 PM
