Can TunerproRT use tunercat files?
Old Oct 18, 2004 | 11:22 AM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
I'm trying to modify and LT1 PROM for a friend of mine; it appears that the only place to get 93 LT1 files is from tunercat. Does anybody have experience/knowledge as to whether I can use my Tunerpro RT to modify the tunercat bins?
thanks
jcj
Old Oct 18, 2004 | 01:27 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
No. Both the ecu and tdf file formats are different.
Old Oct 19, 2004 | 10:04 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
A .bin is a .bin, it's just a bunch of ones and zeros. The interface files are what's different, they tell the program what each one and each zero means. You need the right .ecu file for the LT1 computer if you want to edit with TunerPro.
Old Oct 19, 2004 | 10:10 PM
Car: 88 Camaro SC
Engine: SFI'd 350
oh, duh... Didnt see that it was a bin and not a calibration file. Yeah, so long as the ecu file you ahve has all the addresses correct itll work.
Old Oct 20, 2004 | 12:15 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Actually, it looks like the "poster" may be confused on what bin, tdf and ecu files are. To my knowledge, TunerCat does not supply bins, but TDFs. So if he meant "tdf", your original answer was correct and no "duh" is required.
Old Oct 20, 2004 | 10:03 PM
Axle/Gears: 4.1
well, I worded that poorly...
thanks guys.
Since the only option I can seem to find for modifying the LT1 BIN is from Tunercat; what I really wanted to know was whether I could use my TunerproRT with the Tunercat software.
From the first answer it seems the Editors are different and the Definition files are different....and so much for that.
Old Oct 21, 2004 | 04:28 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
AFAIK, there are LT1 ecu files out there. I've seen DA3 and EE (and EEA).
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Jonas Earl
Sep 27, 2015 07:39 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
