Can anyone help me?!
Old Oct 18, 2004 | 09:43 PM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
I am having idle problems and have datalogged some info but dont know what to do with it or what it means. If I give someone my logs can neone tell me whats going on?
Old Oct 19, 2004 | 12:44 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Try to explain the problem a little here, and let's see what people think. Idle problems can mean ANYTHING, really, there are a million things that can cause problems, but some problems are easy to diagnose.
Old Oct 19, 2004 | 01:38 PM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
My car goes into closed loop and when I stop at lights and let the idle drop it goes down to 600 for a sec and then drops to like 400 then back up and then down again and eventually dies. The problem didn't occur until I put headers on. I left the O2 off at first (ran fine for this duration) cause the hedmans I ordered didnt have a hole and I had to wait 'til I got a bung welded on. I finally got one installed (Bung from Jegs, O2 Bosch Brand New) about 2 months ago right before I moved for school. Then this idle thing started phasing in until it got this bad and now its dieing at lights. Hope that helps a little more.
Old Oct 19, 2004 | 01:44 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I replied to your other post asking the same question.. (why double post it?!?!?!?)
Anyway, sounds like you need a heated O2 sensor. Very common with headers.
Old Oct 19, 2004 | 01:51 PM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
Lots of people like to stick to their different forum sections thats why I posted it more than once, to get several different opinions. Anywayz, thanks for the input I'm gonna give this a shot. Wouldn't surprise me if it ran smooth again afterwards.
Old Oct 19, 2004 | 01:59 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Also, you may have a leak which causes false readings.
Old Oct 19, 2004 | 10:00 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Definitely check for exhaust leaks as they will trick the O2 into thinking you're running lean. Also read the Delco O2 thread.
Old Oct 20, 2004 | 12:32 AM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
Alright, I just got done installing a heated sensor and resetting the computer. It still drops the rpm's a bit at idle. Is this due to the fact that I just reset the comp. and it will even out in a couple days or is something still wrong?
Old Oct 20, 2004 | 12:11 PM
Car: Death Mobile
Engine: 666 c.i.
No, everything should be fine. When adding headers (only) to an otherwise bonestock engine, the ECM will work fine as is.
You have a different problem. Given the only change was the addition of the headers, my immediate reaction is an exhaust leak. In fact, the O2 is so sensitive to exhause leaks, that a minor leak AFTER THE CAT caused my car to run erratically.
I knew I had a small leak, but I didn't think that a small leak after the cat would affect anything and proceeded to do a ton of scans to see if there was something else...nothing stood out. Everything looked fine, except for the erratic idle.
So I went to a muffler shop and had them weld in a new Y-Pipe after the cat and the engine ran perfect. So don't discount a leak, no matter how small. And, if you just "slipped" the headers on in front of the cats, get them welded up too.
I can suggest other things to look at, but given that the problem developed almost immediately after you installed the headers, suggest the problem is with the header install. Re-torque all the bolts and inspect all the parts carefully for leaks.
