Timing table question...
Old Oct 20, 2004 | 12:15 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
OK, if I've got a value of 12 @ LV8 208 and 5000 rpm, that is 12º added to my base of 12º, for a total of 24º, correct?
Old Oct 20, 2004 | 02:49 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Not in $165 ECUs as far as I know. They take the Spark Table value, and do math (subtract base advance) to get that value to be the actual advance.
So, a 24 in the tables (along with the correct base advance in the base advance constant) will have 24° Advance at the engine at that speed/load point. If the ECU knows that the distributor is at (for example) 6° and the tables tell it that it needs 24°, then it subtracts 6 from 24 and uses 18° advance to get 24 at the distributor.
In $6E datastream, it reports 2 spark advances, one based on used advance ignoring base advance, and one using combined advance. The combined advance is close to actual (doesn't contain knock retard if I remember correctly).
Old Oct 20, 2004 | 05:50 PM
Doward's Avatar
Well, actually, I'm using the $3A in the '302 ecu. If anyone has any ideas if that works the same, feel free to let me know
Old Oct 21, 2004 | 09:47 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
Keep this thread going guys, this is one of the areas where I need information in order to make correct changes to my chip. Currently I backed off the timing ($6E) in the main table to eliminate a hot weather knock. That acheived it's purpose but the car is a dog in the rpm band I made the changes in. Now that the weather is cooler I can run the orignial timing settings.
I have both the Holley and the Accel books on tuning MAP computers, but I haven't found one that will work for $6E MAF setups.... A changeover to MAP isn't going to happen for a couple of years most likely with my time and funding restraints. (California Insurance companies are making everyone with a shake roof replace them with something else, that's going to run about 12-14K unless I use asphalt shingles, that only runs $5-6K).
Azrael91966669
25
Jun 20, 2017 04:04 AM
htrdbmr
Aug 18, 2015 12:58 PM
happyhapka
Aug 15, 2015 04:42 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
