Need help datalogging in Chicago area
Old Oct 27, 2004 | 03:34 PM
kevosiroc's Avatar
OK, I have tried and tried and tried to datalog with the Autoprom, my laptop, and all the cables that I think I need. I am still having problems connecting to the ecm with ecm852 software.
Can someone in the Chicago area that knows how to do this help get me started PLEASE? I have all the equipment and software I need I think.......
Old Oct 27, 2004 | 08:27 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Datamaster works with your application, at least until I fix TunerPro (which won't be for a bit). I know datamaster is a bit expensive, but I believe you have 30 free launches.
Old Nov 7, 2004 | 04:06 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Moates software should? work as well.
What cables are you attempting to link to the car with?
Try posting this up on the nw in/south chicago regional board :-)
I dont have alot of free time right now, but there are a couple other tuners in the area very near to you. Could try with their stuff to see if u have hard/software issues.
later
JEremy
Old Nov 7, 2004 | 08:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Need help datalogging in Chicago area
The problem is that the CCM is conversing with the ECM. This is blocking out the freeware scan tool/data loggers. The f-body's don't have a CCM so they work.
There is another thread (i'll try to find it) where I recommend a switch may be placed into the ALDL line to isolate the CCM during times one wishes to data log.
RBob.
{edit: ah, this is an older thread. for anyone looking for the above mentioned thread here it is:
https://www.thirdgen.org/techbb2/sho...hreadid=262214
Old Nov 7, 2004 | 12:12 PM
Morley's Avatar
Try Craig's 851 software. I never was able to get the 852 to connect either, but the 851 works like a champ.
Old Nov 11, 2004 | 02:56 PM
kevosiroc's Avatar
I only found Craig's site to contain ECM852 and ECM850B
Can you please send me ECM851? Or is ECM850B the same?
Old Nov 12, 2004 | 01:42 AM
Morley's Avatar
YOU HAVE MAIL!
851 sent to you.
Old Nov 12, 2004 | 08:26 AM
kevosiroc's Avatar
Thanks, I will give it a try ASAP
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
ULTM8Z
Oct 2, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
