flash and burn users help
Old Nov 20, 2004 | 05:03 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
I got my burner and G1 adaptor form moates.net today. I want to burn my new chip but I need help with the chip addressing. I am using the C2 27sf512 chip instead of the original c256 chip for a 730 ecm. is says on his site to set the start device address to hex 8000 if you orginally had a c256 chip but on flash and burn there is a chip address and a buffer address both with a start address. what do I have to set these two things to. when you select the sf512 chip it gives you a 000000 as start address for both and gives you 00FFFF as the stop address for both. what do I do here?
Old Nov 20, 2004 | 09:50 PM
Morley's Avatar
Change the starting address for the chip to hex 8000
Old Nov 20, 2004 | 09:53 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
And leave the buffer start at 0000
Old Nov 20, 2004 | 09:55 PM
1992rs/ss's Avatar
here is the other thing I just thought of. my bin file is a 64k file. isn't my chip a 64k chip? so wouldn't I just leave it at 0000?
Old Nov 20, 2004 | 10:04 PM
TheGreatJ's Avatar
Typically, when you say you're using a '7730, people assume $8D code, which would require the $8000 offset. Is that the mask you're running? 'Cuz $8D is only 32k.
If it IS a 64k file just leave the offsets at 0000. You can look at the file properties in Windows to make sure what size it is.
Old Nov 21, 2004 | 01:16 PM
Morley's Avatar
Did you "double up" the bin?
Old Nov 21, 2004 | 04:00 PM
1992rs/ss's Avatar
I just got the AXXF bin file off of moates.net and it says under file size that it is a 34k file. is there something wrong here? my saved file became a 64k. I will burn a new chip with the stock 32k file and see what happens
Old Nov 21, 2004 | 04:15 PM
1992rs/ss's Avatar
ok new problem I made sure the file was 32k and then set chip address start to 008000. the end address though doesn't seem to work I get a error message asking if the values are reversed. I have ending address set as 007FFF. if I change the change ending address to 008FFF it will burn. what should both of these be set too. also the buffer settings are 000000 start, and 007FFF ending. can someone lay it out plain and simple what I should be typing in these boxes.
Old Nov 21, 2004 | 05:48 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
make sure your bin is 32k.
buffer start: 0
buffer end: 7FFF
chip start: 8000
chip end: FFFF
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
1MeanZ
Dec 18, 2015 05:39 AM
New2Chevy
Sep 28, 2015 12:35 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
