Oxygen sensor threshold rich/lean table in 6e maf code
Old Nov 22, 2004 | 03:12 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I noticed that this table calls out the cross cound point for stoichiometric as a function of airflow. why would you need such a thing?
I would guess that if the engine were providing the o2 sensor with highly variant f/a ratios then the o2 sensor might have a lag going from one extreme to the other and compensation would be in order.
And I thought that all those threads bashing NB o2 sensors for only knowing 14.7 were saying that there is only one Mv rating the computer could use to find it. All other voltages were unrelatable to a specific f/a ratio.
Seems like one might be able to raise this number for lower airflows to raise the f/a ratio -- but then we get into the whole mess of where the sensor is accurate.
Anybody have ideas?
Old Nov 22, 2004 | 03:32 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
This should help. . .
http://www.diy-efi.org/gmecm/papers/747fuel.txt
Old Nov 23, 2004 | 09:06 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Like said above thats a valid way to do it. Set teh (or a) bias added into the stoich O2 voltage to get it to idle the way you want and then change the MAF tables around where the car idles to try and get the BLMs in line. Although I dont think the MAF cars have such a thing, do they?
Old Nov 23, 2004 | 10:49 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Indeed I do have a table that lists the stoichiometric Mv value as a function of airflow in the 6e.
Old Nov 23, 2004 | 11:30 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Change it and see how it works out. Adding a touch more fuel at low flows will probably help improve the idle.
Old Nov 23, 2004 | 08:16 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Or take some out and get rid of a horribly stinking gas rich idle that comes from a big cam and no cats. Worked for me at least.
Old Nov 23, 2004 | 09:10 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Its different for every motor. The cam probably screws with the O2, anyway. With my stock motor the richer idle seemed to help smooth it a bit.
bbsr72
Apr 2, 2016 09:12 AM
86IROC112
Nov 27, 2015 09:54 AM
dusterbd
Sep 29, 2015 08:40 AM
cking99
Sep 22, 2015 11:33 AM
earlpote
Sep 12, 2015 11:55 AM
