Cleansing a .asm
Old Nov 29, 2004 | 08:49 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Cleansing a .asm
I'm trying to build a .asm, but the document I started with was a .txt. Is there anyway to make sure there's no MS nonsense in it?. I used hex workshop, to look at it, and it *seems* to be right. But, is there a way to make sure before going any further?
Old Nov 29, 2004 | 09:34 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
As long as you didn't use any sort of word processor on that txt file, you should be fine. I typically use Notepad.
If you open it up in notepad and don't see any strange stuff floating around, you should be fine.
Old Nov 29, 2004 | 09:57 PM
92GTA's Avatar
Exactly, use notepad for everything and you'll have nothing to worry about...
Old Nov 29, 2004 | 10:38 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Forget notepad. Go Ultraedit, baby. It is now my standard hex and plain text editor.
www.ultraedit.com
Can't go wrong.
Old Nov 30, 2004 | 06:45 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
www.ultraedit.com
Can't go wrong.
Forget ultraedit, I use Emacs, pico, or Vi.
-- Joe
Old Nov 30, 2004 | 11:51 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
There's a good editir that comes with the simulator THRSim11.
You can find it easy on the net.
It formats in several different formats so you can see errors pretty easy.
The simulator is a demo, but the editor is full version.
I don't know if the editor expires when the demo is done.
It's good for 15 days anyway.
Jp
Old Nov 30, 2004 | 06:47 PM
JP86SS's Avatar
The editor does stay active although the simulator shuts down.
It has a "view" feature to see whitespace and CR/LF also.
Set it for assembly language and it uses color to show different program code and comment items.
dimented24x7
Oct 13, 2009 07:54 PM
BIG 'G'
Dec 9, 2008 10:18 PM
92RS3.1
Jul 14, 2008 07:41 PM
92GTA
33
Sep 19, 2005 12:39 PM
Nate86
Jul 19, 2004 05:52 PM
