mini IDE assembly problems w/$0D
Old Dec 4, 2008 | 10:25 PM
BIG 'G''s Avatar
I'm currently trying to get the OD hac by dimented to assemble, and am eccountering the exact same problems as junkcltr (see post 325 and 327 of tbi guys its time to update) with the program being offset and extended adresses being coded as direct adress. Ive run the file through the mini ide under windows and under dos as suggested by dimented but am getting the same results. Dimented has suggested adding a constant byte to correct the problem. I'm not sure what is meant by a constant byte, or how it is to be used, should it be placed in the .asm file or formatted into the mini ide. definatly would apprreciat the help. thanks
Old Dec 6, 2008 | 12:37 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: mini IDE assembly problems w/$0D
Is it just a few of the addresses being different? I remember fixing a few errors in the original code that used the incorrect addressing modes where used in several places.
Old Dec 9, 2008 | 10:18 PM
BIG 'G''s Avatar
Actually their are quite a few differences, I found four corrections you made at C322, C338, C754, and C77D where you switched from extended to direct addressing. This was offsetting the bin by a total of 4 lines (or maby bytes) which is what i was seeing when comparing bins in tuner pro. Your refference to the constant byte was throwing me off, thought i was making a mistake when converting it to a bin. Turns out my mistake was not re calcing the check sum which changed due to your corrections. I have fixed the checksum and now have the reassembled bin working . Thanks for your help dimented
1992 Trans Am
May 10, 2023 07:19 PM
Cleotiz
Jan 6, 2018 08:56 PM
mhatfield 14
Oct 24, 2015 07:48 AM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
