Power enleanment?
Old Dec 6, 2004 | 08:16 AM
Stevie's Avatar
Power enleanment?
I've just about got my tune perfect but I havent touched PE yet. Since I cant leave well enough alone I'm starting on that now. Looking at both AUJP and ANHT it looks to me like gm actually leans at WOT till you get to the higher rpms from the "POWER ENRICH FUEL/AIR % CHG vs RPM" table. Am I understanding this right? And why do they do that?
Steve
Old Dec 7, 2004 | 03:24 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
There's a Power Enrich vs Ctemp table that'll have about 20% in it at fully warmed.
Old Dec 7, 2004 | 10:01 PM
JPrevost's Avatar
Car: 91 Red Sled
It depends on the temp and engine load in some code. I've seen "negative" values in the DA3 mask (93 Lt1) that is used because other tables that are ALSO used have positive numbers.
I also notice how open loop is almost always richer than closed loop. If you compare the open loop commanded AFRs vs the PE you might also see some correlation. That being said you'll never see an ecm with stock code run an engine with an AFR above stoich, that's just asking for trouble.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
