is it all bad..
Old Dec 6, 2004 | 02:10 PM
devilfish's Avatar
is it all bad..
..if i use the ve tabels from a LT1 6psd vette and the main spark tabel ( lowerd some due to me not having reversed cooling ). As a starting point for my new engine?
LT1 intake
HOT cam
TS 23 heads
HEaders.
Car is 1991 vette 6spd?
Old Dec 6, 2004 | 04:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: is it all bad..
LT1 intake
HOT cam
TS 23 heads
HEaders.
Can't see why not, have to start someplace. Get the engine running, rough in the idle, do some high load data logs, check if there is enough fuel, check the injector DC, adjust from there.
RBob.
Old Dec 6, 2004 | 04:52 PM
91RedFirebird's Avatar
Car: 91 firebird
Transmission: t-56
I put in a Lt4 hot cam set up in a 95 firebird with a 6-speed and mildly ported heads. The owner insisted that the computer would "learn" the new cam (yeah right) it was so lean the header where glowing bright red. He was able to limp it around with stick if it was an auto it would have died if put into gear.
Old Dec 6, 2004 | 11:09 PM
devilfish's Avatar
Re: Re: is it all bad..
RBob.
As this is going to be the first start up after my rebuild. Should I adjust the lower and upper BLM limits , so the ecm can compensate more during cloosed loop action? Bad ide?
Cheers
Old Dec 11, 2004 | 06:26 PM
devilfish's Avatar
Lt1 vs L98 spark tabel.
davidopliger
Feb 3, 2025 09:30 AM
B_Dubya
Aug 26, 2015 05:09 PM
CAMAROJOKESTER
Mar 5, 2009 07:59 PM
hectre13
Nov 30, 2008 03:52 PM
