Info for dissyless ignition
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
This is over my head, but I think there might be some good info on this page.
http://www.vems-group.org/wiki/index...Ignition%2FFaQ
Seems like the ford stuff needs very little input other than the trigger wheel, and a timing signal. From what I gather the trick is giving the ford module a signal that it understands.
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
The thing about using a GM system, such as the Northstar is that you already HAVE the appropriate timing signals!!!! Since you need a trigger wheel anyway, why not just use something that will DIRECTLY interface with the GM ECM????
Car: An Ol Buick
Engine: Vsick
Originally posted by AlexJH
What are people doing for the trigger wheels on SBCs? I've been looking for the past couple of days for crank sensor setups but I haven't had much luck with google.
For a DIY DIS, or CNP, just use a ~90 Caddie Distributor, with the dual sensor distributor.
Then a simple count to 4, or to 8 depending on DIS or CNP, with a Cam sensor reset/count starter. If you use DIS then you'll need to work out 4 coil drivers, or if CNP just use 5v for the triggering, of the coils
Set the min engine run speed real low, and then you don't have to worry about the bypass.
Well, in theory anyway.......
Car: 84 Z28
Originally posted by Grumpy
Why do you need a crank sensor?.
Car: An Ol Buick
Engine: Vsick
Originally posted by JP84Z430HP
Are you talking about the F.A.S T. setup here?
I'm sure if some of the electronically inclined here looked at the Megajoltjr schematics, they could make a similar box that would take the gm ecm signal and drive the ford dis.
They'd probably give you the box if you designed it & gave it back...
Currently, it's about $300 for a MJjr dis used parts setup, but you loose the gm tables. The MJ is map/rpm only, I think there is a mod to make it tps only.
need a few code changes though. I think the ford dis does it's own dwell calc.
Only reason I was looking was because I want CNP.
DIS is the next best I guess...
Car: 84' Monte
the reason I thought it was cool was the fact that it only took one crank sensor to run instead of the crank and cam sensor of the caddy setup. I figured it might be easier to convert the GM signal over to what ever the ford system needed. What kind of a signal does the gm ecm output for timing control? It says the ford module needs a "sawtooth" signal, what ever that means.
Engine: Many
Transmission: Quite a few
if you are retro-fitting a DIS system from a caddy northstar into a thirdgen system(165, 730), you don't need the cam sensor. Its not needed unless you have sequential injection. the module will work with the two crank sensors, for spark control.
Looks like I have a lot of reading to do.
Car: 84 Z28
Actually, the Northstar system will run with just ONE of the crank sensors. The second is there to get it in sync with what cylinder shoud be firinig within the first 180 degrees of crank revolution (or was it 90 deg.?)
I'm assuming that it has the right type of hardened gear to run of the cam in my L98?
I wish we had good junkyards around here in Vancouver, I think I'll have to order one from Ontario or something.
Car: 84' Monte
From what I gathered on the other thread the problem with just running one crank sensor is that the motor would crank over for several seconds before firing, and you had to make a reluctor wheel to send the proper signal. I've never heard of using a 90 caddy dissy before.
The whole reason I want to use the dissyless setup is to get rid of the dissy all together, so I can use an Lt-1 intake if I want, or more importantly I want to set the engine lower and further back in the chassis to help weight distribution. Getting rid of the dissy helps alot in this regard.
Has anyone actually got the caddy setup running?
Car: An Ol Buick
Engine: Vsick
Originally posted by BMmonteSS
Thats the problem, the caddy doesn't have a dissy. From what I gathered on the other thread the problem with just running one crank sensor is that the motor would crank over for several seconds before firing, and you had to make a reluctor wheel to send the proper signal.
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Umm.... I do not believe that the Caddy dizzy will work in a SBC. I have seem it done on a Olds motor, running multi-port and a 730. Bob
Car: An Ol Buick
Engine: Vsick
And there is a dual sensor 4.3L distributor, which would provide additional bits to play with.
Car: 84 Z28
For what I have on it go to: JP Teck
JP
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
A 4.3L dizzy will fit. Just have to adjust the shutter wheel from V6 to V8.
Does the 4.3 dizzy have cam and crank sensor outputs or??
-- Joe
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Originally posted by anesthes
So the caddy dizzy won't fit a SBC ?
