N-bias What is it? And should you play with it?
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Been tuning with my ZT-2 WB. Great tool! Reading RBob's article on IAC tuning I ran into his comment that he wasn't certain what the N-bias was. The article was qwritten sometime ago and I was wondering if there was an update to it particularly addressing
N-bias.
N-bias.
Car: check
Engine: check
Transmission: check
Re: N-bias What is it? And should you play with it?
N-bias.
N-bias.
It's so stupid it makes the kickdown steps look like a good idea. . .
RBob.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
RBob,
Does it have anything to do with the re-set of the IAC's? By increasing the setting, any idea how that shows up in the performance or driveability of the vehicle? How do you tell if lowering or raising it makes a difference?
Car: check
Engine: check
Transmission: check
During the time between kick down and closed loop idle there is an upper RPM limit. To bring the idle RPM below this limit a variable is incremented (stored in RAM). The value stored in this variable is then subtracted from the IAC steps count. This brings the idle down.
Whenever the vehicle speed matches or exceeds the N-Bias term this varibale is set to zero (0). Now, when the vehicle comes to a stop the idle speed is again too high. And again, this same variable is increased in order to bring the idle down.
This stupidity continues until the engine is up to the temperature threshold for closed loop idle. The ECM will then discontinue this increase and zero action and the idle will settle down.
To observe this in action set the N-Bias value (LD5F4) to a low value, say 5 MPH (set the term to 16). Now do a cold start and let the engine warm up for a few minutes. Notice how the idle RPM is brought down to match the cold RPM limit term.
Move the vehicle enough to trip the 5 MPH N-Bias term and come to a stop. Notice how the idle speed is high again. The longer the engine warms up prior to closed loop idle temperature the worse the idle up is at each stop.
Best thing to do is to set the N-Bias term as high as possible. And let the code handle the idle without this interruption.
RBob.
RBob.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
RBob,
WOW! You hit the nail on the head with that one Bob. The last bin I burned, I played with the N-bias and used the number from the APAB bin which had a term of 6. My previous bins have used 5mph or term of 16. As I warm up the car in the garage, the idle finally drops to where its supposed to be, around 850. BUT THEN, as you described, I'll take the car out for a scan. When I get to the first stop, I need to sit there and let the idle drop down, as if something was re-setting the IAC position, and idle down. Usually, this is accompanied by an oscillating idle for several seconds until it settles down. After that, I have no more problem with the idle UNTIL the next time I start the car and go through the whole process again. With the term at 6, the oscillation got much worse. If I don't stop that first time the idle will not be set until I do. Guess I'll try it at 255.
Car: check
Engine: check
Transmission: check
Originally posted by TonyC
Is there any way to change that multiplyer from 3.2 to 1 or lower?
RBob.
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Re: Re: N-bias What is it? And should you play with it?
RBob.
RBob.
If you set the term to 255, and the the term equals MPH*3.2 (255=MPH*3.2) wouldn't this make the N-Bias = 79.6875 MPH?
Wouldn't this pretty much be disabling it? I'm speaking for myself here but I'm not gonna go more than 80 MPH on a cold engine.
OR could you just set the RPM limits higher than where you want it to idle? I'm guessing you're talking about the idle rpm limits @ $5E1 or $5E2?
Car: check
Engine: check
Transmission: check
Re: Re: Re: N-bias What is it? And should you play with it?
Originally posted by V8Astro Captain
I got a good couple of laughs out of that one!
The MPH*3.2 term is limited to a max of 60 MPH. So setting the N-Bias term higher then 60 MPH (192) will disable this 'feature.'
Yes to the $5E1 & $5E2, they are both post-kick down, pre-closed loop idle max idle RPM limiters.
RBob.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
This has turned into a pretty fruitful thread. Anytime you can "jog" a few of RBob's gray matter cells, you get more info.
Thanks RBob!.
Thanks RBob!.
Bob88GTA
Sep 10, 2015 09:07 PM
