E-Prom giving me problems.
Old Dec 29, 2004 | 09:51 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ok every since a while back when i started messing with chips, after i took the original out, this problem has bugged the crap out of me forever. Sometimes when im driving down the road, the SES light will start blinking rapidly, and when this happens all i have to do is take the chip out and re-insert it, like it isnt making good connection or something. What could cause this, its really starting to get very annoying.
Old Dec 30, 2004 | 05:40 AM
Z69's Avatar
Z69
A bad adapter connection.
When you pull the chip you dump the dtc.
Get the codes first to help narrow it down.
Old Dec 30, 2004 | 08:41 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
What is the dtc?
Old Dec 30, 2004 | 08:43 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: E-Prom giving me problems.
Sounds like it's not making a good connection or something.
If it just does it with one chip, then it's probably a bad chip. If it does it with several chips, then you have a poor connection, in the prom to ecm holder/adapter.
Old Dec 31, 2004 | 06:00 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
No it does it with every chip
Old Jan 1, 2005 | 12:55 PM
Maglin's Avatar
I would replace your EPROM Socket with a nice ZIF socket and ensure that you have good solder joints on it when you install it.
I had the same problem on my Talon when I was running a 5 inch EPROM Extention ribbon cable. Could just be that the cable was to long or it wasn't making a good connection.
Also I've noticed that actual EPROM's usually work a lot better than ATMEL chips do. I've had problems with ATMELs just loosing data after time and with a EPROM I've never had that problem. So once I get a good tune I just burn a EPROM and leave it until I mod something else that requires a change.
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Linson
Oct 1, 2015 09:50 PM
