WinALDL datalogging problems with USB AutoProm
Old Jan 6, 2005 | 10:20 PM
jonarotz's Avatar
Car: 91 Z28
I have used my new autoprom on my 91 Z28, using TunerPro RT with no problems. Today I tried to scan my brothers vehicle with WinALDL and no luck. I tried the switches in every position with no luck. It has an 062 ECM which is supported by WinALDL. I will get raw data but nothing else. Also the box at the top flashes numbers the highest I noticed was 5, it also has a grey and red flashing background in this box along with the numbers. I don't have any WinALDL experience, as I normally tune with TunerPro or Datamaster. I would apreciate any help.
Old Jan 7, 2005 | 10:23 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Try this:
- Horizontal switch out, vertical switch up, key off, everything connected.
- Startup WinALDL, set the WinALDL baud rate to 4800. Set COM port to the right one for the AutoProm.
- Turn key on. See if you get the green blinky in WinALDL. If so, all's well.
Hope this helps!
Old Jan 7, 2005 | 10:32 PM
jonarotz's Avatar
Car: 91 Z28
I figured it out, I needed to change the baud rate from 2400 to 4800.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
