DIY Bin Switcher?
Old Jan 8, 2005 | 01:13 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
DIY Bin Switcher?
Searched here.. searched syty.net... dug around diy-efi.org a bit.. came up fairly dry... enough info to do a week's worth of basic electronics research and produce one.. but on the chance I can save myself the time: Does anyone know where one could find schematics and/or a decent explination of how to build a bin switcher?
Old Jan 8, 2005 | 10:44 AM
HaulnA$$'s Avatar
If you haven't done so yet, check this out. http://www.moates.net/gmecm/switchin.html . No schematic but very good info. Enough to come up with a design. All that is needed is to switch the high order address lines to switch "banks" of memory. A hex rotary switch from Digi-Key would work well. HTH
Edit: Also found this. ftp://ftp.diy-efi.org/pub/gmecm/projects/6in1.gif
Old Jan 8, 2005 | 10:59 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I'd use this guidance as well:
- Use pretty good pullups (1k-10k)
- Use some noise reduction if you're planning to use an extension cable (0.1uF parallel caps or something)
Old Jan 9, 2005 | 05:06 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Thanks for the advice, Craig... otherwise, looks like I finally have to sit down and learn more of the inner workings of solid state electronics. Ahh well. knew it would happen eventually
(I understand the basic concept of manually controlling the upper address lines... it's doing so without releasing clouds of expensive japanese smoke that nags at me )
Old Jan 9, 2005 | 06:36 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Originally posted by TechSmurf
(I understand the basic concept of manually controlling the upper address lines... it's doing so without releasing clouds of expensive japanese smoke that nags at me)
No guts, no glory, The chip smoke is one thing, but there's nothing as refreshing as a varnished wood desk top, that's smoldering. Power MOSFETs, do need heatsinks, BTW....
Old Jan 9, 2005 | 09:49 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
This might help in building the BIN switcher.
http://www.diy-efi.org/gmecm/projects/bigeproms.html
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
ULTM8Z
Sep 16, 2015 09:15 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
beast94
Aug 20, 2015 06:44 AM
