What Else will i need besides the AutoProm Package
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
I would like to start burning the Flash EEPROMs. So far All that i have is a laptop computer and i just downloaded TunerPro RT. What else will I need. The following package that i am looking at contains:
APU1 AutoProm Package: USB Version [Model: APU1] $325.00
Product Description: Does everything in one package, one USB-based device! USB-powered, so no power supply needed. Chip burning/reading, datalogging, and realtime emulation. Performs ALDL communications at 160/8192 baud, programs AT29C256, 27SF512, and AM29F040 chips. Has 3-channel 0-5v 10-bit A/D provision fpr wideband and other datalogging. Includes AutoProm device, 28-pin 18-inch emulation cable, OBD1-style ALDL cable CABL1, 6-ft USB cable, 1x 29C256 chip, 1x 27SF512 chip, 1x 29F040 chip, and Mark Mansur's "TunerPro RT" Software license. PLEASE READ through product documentation to understand some of the features of this all-in-one, datalogging, realtime emulation tuning, and chip burning hardware. Keep in mind you'll still need a chip adapter and probably a ZIF, so select them from the Adapters and Sockets categories if you don't have them already. Fully compatible with TunerPro RT and TunerCat.
Is this the package that I need?
I just ordered the autoprom usb version, the gp1 package(plugs into stock memcal so u can use a diffrent chip and keep your stock on in the memcal) , hdr1 memcal header(so i can read stock chip with out taking it off the stock memcal), and two extra AT29C256 chips. Should be here this week. now i just gotta learn how to make a good chip (lots of reading during the past week) i'm pretty sure that the autoprom does everything you need the other stuff just makes it easier no soldering
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
Dragonsys
Sep 25, 2015 03:51 PM
