MAp sensor pins
Old Feb 10, 2005 | 01:55 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
MAp sensor pins
I am in the middle of doing a MAF -> MAP conversion and I can't seem to find any information on what the pins on the MAP sensor are.
I need to know what the A, B and C pins actually are..
for insance.. Pin A -> +5V?, etc.
Can anyone help me out?
My car almost started once then shut down, so it may be either two things. I have my MAP sensor wired wrong, or it may be because I am using the stock AUJP memcal and I didn't put in my chip with VATS disabled
Old Feb 10, 2005 | 02:14 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
http://www.eecis.udel.edu/~davis/z28/ECMs/86to92.txt
That link above may help
MAP Sensor Terminal A = GND
MAP Sensor Terminal B = Singnal
MAP Sensor Terminal C = +5V
Old Feb 10, 2005 | 03:10 PM
Sonar_un's Avatar
Car: '86 T/A
Yeah.. I figured it out.
I got the TA to fire up with the 730 too..
thanks for your help.
I looked at that sheet probabally a hundred times but for some reason it never dawned on me. I think the last time I looked at it.. It was late and I was tired. I had all the wires backwards
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
customblackbird
Oct 1, 2015 04:30 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Ironhead38
Sep 7, 2015 02:26 PM
