TunerPro RT - Datamaster Variances?!?!?
Old Feb 14, 2005 | 10:42 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I've discovered a really strange issue with TunerPro RT and Datamaster: They do NOT report agreeing MAP/vacuum readings on my $8D 730-based setup. No wonder I'm having trouble getting my VE tables right.....
I've confrimed this several times, but TP typically reports 8-10 Kpa less than Datamaster under the same conditions. I can best show this at idle with a totally warmed up motor. I can log with DM, then switch to TP, back to DM, then back to TP - all without ever shutting off the motor seeing any appreciable engine temperature or RPM changes. TP will report 34 -36 KPa at this idle and DM will report 43-45. I think I've seen fairly similar differences at highway cruise speeds, but can not confirm these since it's hard to switch back and forth while driving at 60-70 MPH.....
Has anyone else seen or noticed anything like this before? I wonder if my ECU file for TP-RT is incorrect somehow. I'm using one labelled Super_8dm2, which I got from Mark's site, but maybe it's different or off somehow?
Anyone have a 3rd product or method I can use to see which one is correct? Or maybe a different "correct" TP ECU file to see if that's my problem? Both products have their advantages, but I see no reason why they should have different values for the same "conditions".
What am I missing?
Old Feb 14, 2005 | 10:47 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Try a mechanical vac gauge at idle.
Old Feb 14, 2005 | 10:55 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
I can agree with the tunerpro definition being different. I had to make a change in the tunerpro aldl definition to get it to agree with datamaster and 2 vacuum gauges as well as my Genesis scanner.
Old Feb 14, 2005 | 11:00 PM
vernw's Avatar
What change did you have to make? Would you be willing to share your ECU file with a fellow Texan? Pretty please?
Old Feb 15, 2005 | 12:30 AM
eric305TPI's Avatar
I'll get it to you tonight once I get my laptop charged.
Old Feb 15, 2005 | 08:38 AM
vernw's Avatar
Thanks!!! My e-mail is vern.walls@parsons.com
Old Feb 15, 2005 | 01:31 PM
JPrevost's Avatar
Car: 91 Red Sled
There are 2 main MAP formulas used.
MAP kpa = (raw byte) * 0.3125 + 20
MAP kpa = (raw byte) * 0.369 + 10.415
So the range of the 1st formula is 20-99.7kpa and the 2nd is 10.415-104.5kpa.
Is this the problem or is there something else that is conflicting?
Old Feb 15, 2005 | 02:09 PM
vernw's Avatar
Hmmm, neither of those formulas match the ECU I have (version 1.01). It's using a factor of .392157 and has zero for the offset.
I was lucky enough to have a 1.02 version just e-mailed to me one of our members (Thanks, eric305TPI!!!). It just shows the Raw MAP value. Which formula would you recommend using for a 91 with $8D (speed density) on a 730?
Old Feb 15, 2005 | 02:52 PM
eric305TPI's Avatar
Here is where I have it located if anyone else wants it.
http://home.houston.rr.com/lisfamily/1227730.ads
If anyone sees something out of wack PLEASE let me know.
Old Feb 15, 2005 | 06:52 PM
vernw's Avatar
That first formula, which is what Eric has in the above ADS file, solved the discrepancies.
THANKS, EVERYONE!!!!
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
GTAman
Sep 21, 2015 09:57 AM
tmellott89
Aug 16, 2015 02:58 PM
