Bad temp sensor?
Old Feb 27, 2005 | 06:53 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Bad temp sensor?
I hear a lot of guys say that if your manifold temp sensor is bad, your car will not run correctly. I have issues with starting a cold motor and having to work the peddle until warm. If I data log with TunerPro I can see the temp of the engine. Does that info. come from the manifold temp sensor or another sensor?
Old Feb 27, 2005 | 08:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There is both the coolant temp and intake/manifold temperature sensors. After sitting over night do a key on engine off and read the sensor values. They should be within a couple of degrees of each other. And be within a couple of degrees of ambient. Else something isn't right.
RBob.
Old Feb 27, 2005 | 10:43 PM
11sORbust's Avatar
The IAC is the only thing that "controls" cold start. Make sure the minimum air rate has been set. If that's fine then check for a vacuum leak or sticky/dirty (or bad) IAC.
Old Feb 27, 2005 | 10:45 PM
11sORbust's Avatar
coolant temp comes from the 2 wire sensor on your intake's coolant passage. The Air Intake sensor is on the air cleaner or underside of plenum.
Cornholio7979
Sep 20, 2018 02:31 AM
Bstrang6
Sep 8, 2015 04:29 PM
squiggy2
Aug 9, 2015 09:30 PM
