Eprom size?
Car: '91 TA vert
Engine: turboLSx
Eprom size?
Tried some search keywords, not exactly sure what keywords to use(the search wasn't helpful at all). What size eprom do I have for a 91 lb9 with the 730 ecm? I'm ordering the prominator and I'm alittle confused at that. Also, do I need the memcal adapter?
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I use Atmel 29c256EE chips and yes u will need moates adapter unless u want to solder your stock memcal :-)
My vote is on getting the adapter, I have soldered on the memcal and dont recommend it.
later
Jeremy
later
Jeremy
Car: '91 TA vert
Engine: turboLSx
Okay, go for memcal adapter. Awesome.
So what size chips are those? The order form says "27x16 - 27x040" ?
www.moates.net
at29c256
at29c256
Pac J
May 17, 2020 10:44 AM
