O2 Bias Voltage in 730?
Old Apr 5, 2005 | 06:22 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I'm looking through my bin after doing a search i see that the O2 Bias voltage needs to be changed to compensate for larger overlap cams. In my bin file i do not see it, the only thing close i see is AIR Rich/Lean Difference. Am i missing it all together? Hopefully soon my eyes will stop burning so i can read your replys.
Edit: Maybe better yet i should ask am i going about tuning my idle correctly?
Old Apr 5, 2005 | 11:56 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Are u using TC or TunerPro?
I'm not sure of TunerPro since I use TC 99% of the time.
IT is listed there as 02 rich/lean high and 02 rich lean low w/ idle in the name also.
If I get a chance and gig out the other puter I will post actual names
later
Jeremy
Old Apr 5, 2005 | 01:36 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
I am using TunerPro RT and s_aujp_ccp_v3.bin w/ 8dv03.ecu
I'm just trying to keep the car from burning so much fuel at idle. My blms at idle (900 rpm) are 96 with a map reading of 42-43 kpa.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Elephantismo
Feb 13, 2019 12:51 AM
327IROC85
Sep 23, 2015 12:11 AM
eustodp
Sep 20, 2015 05:09 PM
ULTM8Z
Sep 16, 2015 09:15 AM
